Cavitating 21
  • Cavitating 21
    On my last trip in some good swell/wave my 21 with a bracket was cavitating to a point the the engine would lose contact with the water. What would be a "fix" for this. jack plate ,or a longer shaft?
    Pro's and cons of each?
    Remove bracket
      If your loosing bite in a following sea you need to lower your engine a notch or 2. Not a bad job. Lots of times we raise our engines up to the point of perfect top end but that hurts the performance off shore in a following sea....
        With a full transom removing the bracket ,well you know.[V]
          It's down as far as it can be moved.
            Brackets are great in that they give more room. Some hills seem to handle better than others. A while back I remember someone having the same problem and they eventually removed brack and cut transom back to 25. My initial reply came access wrong. Sorry for that. I hope You can remedy the cavitation/porpoise issue.
              http://www.permatrimmarine.com/
