I have a 1979 Mako 182...the Backcountry...that is basically a classic 17' they cut the sides down, decked for multiple storage, and added sponsons out back. I am having a fuel related issue that I have a question but I have done the following with the resto rebuild...new 3/8" fuel line from tank to outboard, new fuel filler hose, etc. The motor starves for fuel above 3,000 rpms and when it does the primer bulb goes flat as in under suction from motor and tank not letting fuel in the system. Thinking it was the fuel water separator filter I did replace it twice as of now with 10 hours on the rig. The tank was cleaned prior to getting things buckled up and the first filter showed a little red grit in it so I figured it was just some stuff I could not get.
The only thing I can think of is either a pickup screen getting something lodged in it...but wouldn't think there would be anything left in there to do so...or an anti-siphon valve not doing what it's suppose to. I did pull the fuel hose at the filter and blew back with no issues early on...could hear air bubbling in the fuel tank.
So, does anyone know if these old classic 17's had an anti-siphon valve in the fuel pickup in the tank...or a pickup screen for that matter?
