Bennett Tabs not responding?
  • Bennett Tabs not responding?
    Have barely used the boat after winter storage,only 3rd time out and 1st time on plane, but had an uneven load on the boat today, doesn't seem to be any response from the tabs. Gonna look tomorrow if somehow is low on fluid, which it shouldn't be because any hydraulic system should be a perfectly closed system. But assuming fluid is fine, was planning on someone else at the helm, hitting both switches at different intervals to see if I can feel the pump trying to work? If that doesn't work checking any inline fuse that might be in the system, but if the pump isn't kicking on when someone is hitting the switch, should I think its the solenoid? Any list of troubleshooting anyone recommends?
    got them working thanks anyway
