1981__ mako 235 bow light__wiring
  • 1981__ mako 235 bow light__wiring
    hello guys can any of you tell me how mako ran the blk/ grey wires from the bow running light to the console. i have removed my console to address several problems BUT have created several more dont see the wire under the console. if push goes to shove are there any recommendations on how I should run a new one?? thanks in advance
    Elizabeth King
    on my 1985 21B it comes back on the port side , and under the console by the port stuffing tube.
    Check behind the plate near the fuel filler, it likely ran there and then followed the channel the fuel fill hoses took to the top of the tank/under the console.
      ah ha thanks for the reply great starting point there is a hole drilled in the side of that pipe with a red and black wire comming in from the side maybe someone spliced red wire in at some point thanks will check it tonite
      Elizabeth King
