Through Hull Transducer__- 236
  • Through Hull Transducer__- 236
    So I need to replace the depth sounder on our 236, and have an older factory refurbished Garmin unit with GPS, depth, fish finder, and radar capabilities that my father in-law gave me when he upgraded his on their Parker. I would like to avoid cutting a hole in the sole of the boat, and don't want a transom hung transducer, can I mount inside and have the transducer shoot through the hull? That's the way the current one is mounted I think, appears to be encased in glass.
    12 Smokercraft[br]17 Mako CC[br]18 Marshall Sanderling[br]20 Ellis Sport Fisherman (sold)[br]21 Kencraft CC (sold)[br]236 Mako CC
    sand the hull smooth and use epoxy..try not to get any air bubbles in the epoxy.
      I have an airmar P79 shoot thru. Works fine up to 500-600 feet with my Simrad NSS8. Can read 1000 most times, but that is the upper limit.
      Simple install. Cleaned the spot, siliconed it down, filled with antifreeze. plug and play.
      I installed mine just off the centerline under the transmission. Accessed from the hatch behind the console.
      [br]DonK[br]Boca Raton, FL[br]1979 236IB: \'The Fish Tank\'[br]1979 Backcountry 18 \'Boner\'[br]<>< <>< <>< <>< ><> J[br]Redneck Troubleshooting:[br]1) If it moves, but ain\'t supposed to, use Duct Tape[br]2) If it don\'t move, but supposed to, use WD40[br]3) If that don\'t fix it, it\'s electrical![br]
        Thanks to both of you for your input, looks like I have a good option and can avoid cutting a hole in the bottom of the boat.
