Grounding fuel fill
  • mrdelgado
    To add to this, my boat also has a ground plate to bond the whole boats grounding system. They come in different sizes, but here's an example
    https://shop.hamiltonmarine.com/prod...CABEgKtn_D_BwE
  • Ebwalk
    Thanks! So helpful!
  • Triplecrownnc
    Originally posted by Green Monstah
    When I replaced mine the ground wire was attached the bottom side of the fuel filler machine screws with a lock washer and nut.
    Yes, through bolt the fuel fill, add the ground wire with a shrink fitting on it to one of the bolts, then add a second lock nut. The ground wire goes to the fuel tank and then to the negative on your battery.
  • Green Monstah
  • Ebwalk
    started a topic Grounding fuel fill
    Grounding fuel fill
    Hi. Im replacing the tank on My Mako 231 and pulled the fuel fill to replace the fill line I dont see any lug to connect a grounding wire
    Did it fall off? Do I need to replace it? Thanks for your help!
    Bob
