So Im re installing two much larger bilge pumps on my 19. The two pumps are currently discharging out of the starboard side rear above the useless floor locker. I need to run 1 1/8 lines and thru hull discharge ports.
My question is to make my life much much easier could I install the thru hull discharge ports out of my plastic splash plates at the stern ?
Is there a reason you shouldnt discharge from the starboard side stern ?
This location would actually be higher than the current gunwale location.
