So ive had a couple members on this forum tell me that my 1970 19 should be a self bailing design. I have been pondering this a while not and cant figure out how that may be. THe hull does not appear to have any scuppers installed on the gunwales or the transom that I can see anywere near the floor level.
I am going to be docking/slipping the boat this year and I am very nervouse about deck water and rain/storms etc.
THe boat currently has 2 newer bilge pumps on board, one 750 GPH running off an internal float switch in the hull bilge and another above deck in the deck sump that is wired to a manuel on off switch.
Should I be adding a third pump to the system or do you guys think the two 750 GPH pumps will do the trick ?
I have two 12 volt deep cycle batterys under the console currently and I will keep them on a charger or solar trickle depending on power options at the dock.
Should I add a third smaller 12v battery that is strictly for the hull bilge ? If so I would have a dedicated charger for it also.
I am very nervouse about it, this is an old hull, in suprisingly good condition and I dont want to see anything bad happen to her.
Trying my best to deture any issues ahead of time.
Thanks !
Thanks !
