Livewell - Before and After
  • Livewell - Before and After
    When re-powering this winter, I discovered that my livewell fittings were very brittle and in one instance a 90 degree fitting actually broke off in my hand! The system never worked correctly (in my estimation) and it seemed to be over-engineered with too many valves and fittings. Most troubling were the plastic fittings and shutoffs.
    I removed all of the existing pumps, hoses, valves, shutoffs, and fittings and used all new stuff including bronze shut offs and new pumps.
    I really tried to simplify the system and moved the In-flow line to the bait tank to the BOTTOM of the tank and left the Over-flow line up at the top of the tank. This way, I will fill from the bottom versus the original design of filling from the top.
    I should be launching in the next few weeks and I'll keep you guys posted.
    Here are the before and after photos...
    Definitely keep us posted Id like to do the same if it works well .
    1994 Mako 201 Evinrude G2 150HO
      simple is always better. It would be better to switch the lines, fill from the top and drain from the bottom using a standpipe to regulate the water level. When you are done, simple remove the pipe and the well will drain.
