Adding raw water wash down to our 1993 221b. I cut the water drain line from the top of the fuel tank 2 years ago. It now drains into bildge. There is never any water draining off the fuel tank that I know of.
The outlet below water line is capped but operable. Considering adding a seacock valve and supplying raw water from that outlet.
Jadsco 5.0 Hot Shot
Anyone with the same boat have suggestions for:
1) Pump placement ?
2) Using tank drain outlet to supply raw water?
3) Plan to drill and mount a quick connect Jabsco flush mount fitting through the bulkhead wall close to the starboard side .
Thoughts.
Jadsco 5.0 Hot Shot
1) Pump placement ?
Thoughts.
