I pulled the tank from my '87 Mako 23' and guess what? No appreciable crevice corrosion despite horribly soaked water-impregnated foam. (I'm still inspecting it, but nothing obvious) well I am this far into it, I am going to replace the tank anyway. Here's my question:
there are six 3" holes in the floor of the coffin, probably to push in the foam. Well, that foam is completely water soaked. I don't have it in me to pull the hull from the deck and totally strip out the bad foam. Is there an interim fix that i can use to remove most of the bad foam? Can I cut more holes in the floor of the coffin or is it structural in some way? Thanks for your thoughts.
