I recently installed a Mercury 4 Stroke 150 on my 1988 Mako 20 replacing the original Black Max (served me well!)
I chose the Mec in part because of it's lighter weight compared to the Yamaha, Honda and others (about 40 lbs lighter than Yamaha...and $4000 less!). Even so, the added weight of the 4 Stroke compared to the old 2 stroke Black Max brings the water line up to the bottom edge of the scupper drains in the transom.
To shift some weight forward I want to move the two batteries (total weight about 100 lbs) from their present location in the stern, up, and under the center console. The distance from the old to new location will mean a battery cable run of 18 ft. There appears to be plenty of room under the console and space in the port wiring chase to do the job.
My questions:
1) Will 4 gauge cable work for this distance...(4 is much less costly than 2 gauge but I want to do it right, not cheap)
2) Has anyone done this mod and what issues did you encounter?
Thanks Much for your advice!! Chuck McB
My questions:
