Bracket weep hole
  • Bracket weep hole
    I have a weep hole at the bottom of my outboard bracket. It had a plastic threaded plug in it wich broke. I cant seem to find a replacement. A 5/8-18 tap seems to thread in pretty well. Im thinking about putting in a short ss bolt. Any ideas on were I couldfind the proper plug?
    76 mako 25[br]
    Most people will use the bolt. I currently do not have a threaded hole but want to add one.
      should be 3/8 pipe plug - actual od very near 5/8" and 18 tpi
      use a plastic or aluminum plug with lots of pipe thread sealant
        YES !!! Using a stainless bolt on an aluminum bracket will start galvanic corrosion, and you don't want that. So either the same metal, or plastic.
          Thank you for your responses. I did try a 3/8 plug although it does not thread in.
          76 mako 25[br]
