Best fuel line??
  • Best fuel line??
    I'm almost positive I have a fuel line issue
    the tank and lines were installed in 2009.
    used some ethanol in the beginning for 3-4 years
    now that the good non-ethanol is easily attainable I only use it.
    swapped my engine from a 94 200 yami to a 99 fuel injected one
    just started having issues 6 months ago.
    narrowed it down to fuel supply line tank to engine.
    What is the best under deck line to replace what I have with.
    1977 Mako 21 200 yamaha[br]PSL Fl[br]
    As much as I hated to do it, I went to West Marine and bought the fuel line they carry as it is good for ethanol.
    The fuel line with the lining in it I hear is the worst.
      Shields A1-15.
      Check to see what you have now. If it's black there should be numbers on the side.
        What I have now is not A1-15 I saw other numbers on it can't remember what they were, it is not lined and it has a red stripe running lengthwise on it not sure of the numbers on it
        I have a piece of the A1-15 (new) I split it open it is lined
        scared to use the lined stuff
          The stuff I am using is not lined, black, cannot recall if it had a stripe on it, and when you cut it there are fibers or line looking stuff in it for rigidity.
            The hose I have is
            "MPI premium fuel SAE J1527 USCG type A1 iso 7840-A1"
            Doesn't say A1-15 just A1 only and its not lined.
            the west marine shields A1-15 is lined I cut that one open also.
            They both have a fiber reinforcement in the middle.
              I'm about to change mine out as well. I had a friend tell me the local NAPA sells ethanol resistant line.
              Someone else told me that a local marine store sell some sort of "blue" marine fuel line that comes with a lifetime warranty. Haven't looked much into that.
              1989 Classic Mako 191 - \'Tequila Rose\'
                "Shields" A1-15
                  Myself, I would stay away from the NAPA stuff unless they happen to carry the USCG approved hose.
                  Certain USCG hose ratings have to do with how long the fuel is actually within the hose...as in one rating for fuel supply line, a different rating for filler hose that only contacts fuel for a very short time...then still a different rating for fuel tank vent hose.
                  Yes, automotive fuel hose "may work", but I wouldn't want to explain my choice of hose to an insurance adjuster or the USCG if an accident happens to toast my boat.
                  See the section "fuel line ratings explained".
                  1992 211 w/175 OptiMax
                  Glen Campbell, Pa.
                    Appreciate the heads up. I'll definitely look into the A1-15 when I redo my lines this winter.
                      The brand new Shields A1-15 "un-used" I split open was lined
                      its probably ok if you are sure there is no ethanol used
                        From one of many sites
                        SAE J1527 Type A1-15 - ISO 7840. Low permeation fuel hose has a plastic barrier veneer with NBR outer layer tube to limit permeation. Polyester reinforced and complies with EPA and CARB low permeation requirements. Weather/UV resistant NBR/PVC cover.
                        Fuel feed - gasoline up to 85% ethanol blended fuels / diesel / bio-diesel all blends
                          I have had several problems with the lined hose when working with certain barb connections. It will tear or roll back the lining far to easily and you get premature failure around the Fuel Water separator of the tank fitting itself. I have also seen blistering where gasoline was forced between the lining and the softer cord reinforced inner lining. It is a real pain in the arse to work with.
