About to install my second-hand tabs and need to convert the upper hinge of my cylinder rams. They presently have the hinge with external line and I want to install the standard hinge, I'm assuming there's no issue with this and also assuming (hoping) that new O-rings will come standard when I order the new hinges.
The first question I have is regarding the mounting of the planes. In reading Bennett's installation manual (classic tabs), it references a backing plate, which I do not have. This appears to be installed between the plane and the transom and I really don't understand it's purpose. The stainless seems plenty beefy enough to where I wouldn't have to worry about cupping the metal from tightening it to the transom. Is this backing plate there to serve as a standoff for the plane hinge or something? As I said, I don't have this backing plate. I can fabricate one easily enough if it's necessary but what am I looking at-1/8" stainless?
Secondly, I do not have the brass nipples/90's to go through the transom. Is there anything special about the thread pattern or can I just grab any old brass nipple/90 of appropriate size to mount to my upper hinge? It would be a bitch to bugger up the threads on new hinges. My local supplier stocks the ferruled nuts but no other Bennett hardware. I can always order them but if there is no difference, I'd just as soon mount these right up. I'm approaching 2 years and beginning to get a little anxious as I'm getting closer and closer to the finish line.
Appreciate anyone's input...
