The deck on my boat (1975) has several soft spots and spider cracks and needs to be replaced. I'm putting a new fuel tank in so I figure I might as well work this in to the project while I'm at it. There are some areas where the deck almost feels swollen, making me think there is some serious waterlogging in the foam/wood
I've read several different ways to "skin the cat". Which is best? Feel free to give other suggestions.
1. Cut the deck, leaving a 3" lip around the edge. Use the lip to attach a 5" shelf to the bottom of the lip, to give the new marine plywood something to sit on.
2. Cut the deck entirely, right up to the edge.
3. Cut the top layer of the deck out and remove the old core, leaving in the bottom layer to put the new plywood on. (This is one that sounds easiest, but I won't do since I need access under the boat to replace foam and check the stringers.)
The livewell compartments (one bow, two stern) are in decent shape, do I just cut around them and keep them in/bond them to the new deck?
Once the old deck is out, foam replaced, etc, I'd do the following:
1. Cut 3/4" marine grade plywood to size and coat both sides in resin. Fix to deck.
2. Fiberglass new deck. Then primer and finish (Thoughts on Interlux Perfection over Epoxy PrimeKote?)
3. Non-skid
As you can see from the pics, it doesn't LOOK bad, but walking on it you really feel it.
3. Non-skid
