1993 mako 221 b engine shaft length
  • 1993 mako 221 b engine shaft length
    Hello, I have a 1993 221 b that needs an engine. I was hoping some that has the same boat could tell me the engine shaft length for the boat. I think it is a 25" but have also heard otherwise by some. I am looking at a new evinrude G2 25" shaft that I'm getting at a great price. Your input is greatly appreciated. Thank you.
    I have a 95 232 which is the same boat just renamed for 95 up. The engine is a 25" shaft.
      Measure from the bottom of hull to top of clamping board. Different brackets are made for different legs.
        My 21b uses a 25" on the standard transom - I can not speak for the bracket, but will assume if it is same height as original transom, then 25"
        My engines sits 2 bolt holes up from bottom
          I have a new to me 1992 221b that has a 25” shaft. Seems to run good.
