224 wet rod boxes
  • 224 wet rod boxes
    Does anybody else have this problem or give me a solution to the problem. Kinda hard to tell in the pics but the rod boxes on the floor of the 224 love to hold water on my boat. With no drain in them i hate to leave things in there as the water just love to sit there and accumulate.
    Looks to me like they forgot to put the drain holes in yours. Mine and others I've seen has drain holes in the corner going into the gutter. The drain holes are a little on the small side and sometimes clog. I often thought about enlarging the drains a little bit but it never bothered me enough to get the drill out and do it. I just keep the boat hook, gaffs and brushes in there.
      Here is where the drain hole should be. Its a 1/4 inch drill bit.
        so do you just drill a hole in that area and leave it as is after you drill it? Is there anything you should put in the hole?
