mercruiser seawater pump....help!!!!
  • mercruiser seawater pump....help!!!!
    ive got a 97 5.7 merc. heres the problem, the other day after runing the boat all over stoping and starting a number of times with no problems, well the last time i fired it up the sea water pump was frozen. after removing the belt i was able to turn the pulley backwards a bit then forwwards and that seemed to free it up and it worked fine all the way back in. after going back out again i had the same problem about 25% of the time i tried to start it. what do you guys think
    1975 23cc i/o concord new hampshire
    If it were me, the first time it failed, I would have pulled it and tried to rebuild it.
    If it's too far gone to rebuild, than replace it. That's just way too important a part to let it go untouched.
    I think if you do some searches on line, you should be able to find rebuild kits for it.
    I just did a quick search and found one for about $100.00.
    It could be easy to do, it could be hard, it all depends on how corroded your pump is.
    If it's real bad, it might be easier to replace it.
      i did a rebuild of the pump under 100 hrs ago, but do intend to take it apart tommoro and have a look see
        Its probably the bearings in the pump itself not the impeller. Most of the time when we go thru a pump we forget about the shaft bearings./ Now its time. You may need maching shop help with that but a new pump is not that bad.
        These folks have your pump as cheep as anywhere. dave
        http://www.amarket.com
