Boat is a 1978 Mako 21. On the first run after a 2-year layup, it appears that the fish well under the floor aft of the console is leaking slowly into the bilge. Water for the well enters the well though a thru-hull fitting on the transom. Control valve is in the bilge and accessed from the round port in the rear access panel by the transom. The tank fills slowly with the valve closed, so the valve is probably shot.
I've plugged it at the tru-hull for the quick fix, but have others encountered the problem and, if so, what's the best mid term solution that doesn't involve lengthy haul-outs and effing floor replacements?
Erie Mako
Erie Mako
