Engine vibrations
  • Engine vibrations
    Here's the latest drama. Both engines run extremely well up to 4200 rpm, ~ 40mph. When I jump up to 4500rpm at 43mph both engines start to vibrate side to side. I've tried with the engines tilted up and down, tabs all the way up and down, and all combinations of each. Could this be a problem with a prop? Maybe out of shape just a little that it's not noticable until the higher RPMs? Any ideas?
    prop was the 1st thing I throught. You might pull'em and swing by the prop shop for a quick check.
      also Artie check the little trim tab plate that adjusts your steering comp. one could have come loose and turned on you. causing the two motors to fight one another.
        Artie,
        While I'm a tad embarrassed to admit it, I bumped and lightly bent one blade of the port engine prop, the first day out after mounting the "oriental twins" (A.K.A... Suzy Fook-U & Suzy Fook-Me). It caused EXACTLY what you've described.
        OB1
          Played with the correction tabs and the same vibration. Gonna pull the props next week and have them looked at. Thanks for the help guys.
            Artie, I am inclined to agree with the others that it is probably a prop problem. But, heres a different thought: Maybe you have some trash in the fuel system and have constricted filters. That would be consistent with only seeing symptoms at higher speed. I would think if your props were bent that bad that it would be apparent at lower than 45k rpm.
              A past trip to Venice might ring a bell when you hugged the shore a little to much!!! [][:0] Just go get you twin E-tecs and go back to Africa so I can catch some FISH!!! A 32' Regulator doesn't have any vibrations. Maybe that is the solution!!![8D][8D]
              Your Loving Brother,
              Scottie
              Scott Sutherland[br]\"Overworked Brother\"[br]www.thedockgulfport.com[br][br]
