I have a 1985 224, and I either need to replace the wobble rollers (32 of them devils) at about $9.00 each or change the trailer to a set of bunks. I have always gotten good advice before so I am asking which way I should go. For you guys who have had both types of trailers (bunks vs. rollers) or experience with both types of trailers. Should I replace the rollers or go to a bunk type of set-up?? Which do you guys think will be cheaper, quicker, etc. Also if you know where I can get cheaper rollers let me know. The rollers are 3 1/2" Dia. 3 1/4" long, with a 1" shaft size. Since I would be replacing all the rollers, if they were a different dia. it would be ok, just something close. I guess the length and shaft size are the most important numbers. Hell, I would even use used rollers if they were in good shape. I await your advice[
