Strength of fiberglass lay up
  • Strength of fiberglass lay up
    How can i determine how strong a particular layup schedule will be? if i am using a divinicell panel how much fiberglass do i need to put on each side, ie for side panels of a console or a hardtop? will 2 layers of 6oz fabric be stronger or weaker than 1 layer of 12oz fabric.
    26 Blackwatch[br]Larkspur, CA.
    I would assume the plywood principle applies here. Multiple layers glued together form a stronger product then on thick single layer.
    Just a guess....any pros care to chime in, Warthog, Ring, etc.?
    Jones Inlet, Long Island
      The real answer to that quetion is to have a lab test it.
      I know that's not really what you wanted to fool with, but it's the correct answer.
      if i am using a divinicell panel how much fiberglass do i need to put on each side.
      What is the thickness of the Divenacell panel?
      The consoles on my boat are 3/8in Divenacell. There is a 12oz biaxal +45/-45 and 6oz or 8oz regular weave glass on top of that on each side.
        i was thinking of using 3/8 or 1/2 inside the cabin, new bunk with storage and battery boxes underneath, and walls for head. 1/2 or 3/4 for exterior panels. 2 layers of 1/2 with fiberglass in between for hardtop. I want to be able to stand on the hardtop. with a crows newts or small "tower".
          It doesn't need glass between the 2 piece's of 1/2in.
          Just glue them together with epoxy and with a notched trowl spread epoxy/Cabisol.
          the top core on mine is 1 1/4in.
          2 layer's of 1808 0/90 & +45/-45. Top that with some 6 or 8oz for a smooth surface.
          Tool's to form a nice radius on the edges.
          3 layers of 6 or 8oz to cover the edges. 2in,3in & 4in wide.
          You will need to use this system for mounting thing's.
          http://bertram31.com/proj/tips/sleeving.htm
          You can bore a hole oversize. 1in hole for a 1/4in fastner and fill it with epoxy/Cabisol and redrill the 1/4in hole in the center.
