My DT140 seems to be rattling its shift cable loose inside the motor right at the (sorry it's early and I can't form a sentence) "thingy" that connects the cable to the shift arm.
Since the "thingy" is threaded so turning it one way will tighten down on both the cable and the arm and loosen both by turning the other way, it doesn't seem that locking nuts on either side will prevent it from loosening...only tightening. [?][?]
I only seem to have a problem with this as I idle back to the dock after going out for a ride and pounding it through the inlet. I have to pop the cover off, tighten it by hand, just to make it in all the way. Otherwise it will just drag the prop until I really juice it, etc.
