Pete (Sorry !) my pitch is 21.......1992 motor. Ya might want to add a prop manufactor column, as is seems boats behave differently with different brands. Mine is OMC SST
I just had a thought.... it seems we are looking for some sort of a table-based output of raw data. I might be able to hack a quickie database program next week to keep track of these numbers via a web link.
I'll see what I can conjure up.
-Pat.
Pat, whatever you think is best/easiest but what i'm doing now only takes a few minutes to update and post. Now i just have to get out in my boat and get some #'s.
Pete[br]MaColAh III [br]93\' 261b[br]HO 200 hp ETEC\'s[br]Cape Cod[br]
47-49 MPH at full/hvy/moderate loadings, and 42-44 MPH at lighter loadings, Which I suspect is a result of some minor cavitation issues I've yet to get corrected at the lighter loadings.
Also, the MPG figure I gave is a tad off. After recounting our trip last night while unloading all the gear, it seems I forgot to include the miles from one full day of running, so after refiguring that day, it's really closer to something like 2.9 -to- 3 MPG, albeit that also includes a BUNCH (something like close to 6 hours) of idle/trolling speed time.
OB1
PS: I'm running OEM Suzy alum 3-blade (19 PITCH x 14.25" Dia.) props. I originally tried to get by with Suzy's 3-blade alum 21's, which worked fine @ sea level and up to 1700 ft elev., (trying the 21's was all before I added the armstrong bracket, and enclosed the transom), but the motors weren't strong enough to pull the 21's @ 3700 ft elev., so I was forced to the 19's.) Am giving some consideration to trying some SS 19's, but haven't got enough of the rest of the minor things sorted out yet, so that will have to wait.
