Michigan Dave ..
  • Michigan Dave ..
    You've got mail... let me know what you think!
    So it was you!! I could not tell who it was., anyway I wrote you a chapter on electronic ign. conversions ect. if I was on target lets bring it to the forum so others can benifit. If I was all wrong lets not tell anyone[:I][:I]. dave.
      Well close, I decided to chuck the points and go with an electronic points replacement "upgrade". Just replaced the points with a magnetic switch, so no big deal.
      The distributor is an old Mallory YL flat head with mechanical advance only. The electronic pack mounted in a different position in the distributor from the original points. I'm guessing around 5 degrees retarded. So, I've been advancing the timing to try and get it back to what feels like the performance I expect.
      I'm at about 17 BTDC and it is very close, still a little stumble right off idle at full throttle. However, I didn't want to get too much advance in there since I knew I wouldn't be able to hear any pinging. I'll probably go as much as 20 before taking any next steps involving math and degree wheels [:u]. It's definitely not to the point of being difficult to re-start (unless I let it sit to long, then we get into the whole other story of the dripping carb).
      Thought I'd check to see if you'd gone through this and had a magic number for me.
      Didn't mean to leave the rest of you guys out of the fun, but its just an old ski boat that seems to need a lot of TLC these days.
      Thanks!
      Ben
        If I were going to replace a dist. in a motor now. hand's down it would be a Mallory Unlite unit.
        http://go.mrgasket.com/ProductsListB...n=12&BrandID=0
        ylu series unilite electronic dist.
        Mallory's YLU Series Distributor replaces original equipment marine distributors with a new modern design that combines the triggering device and amplifier into a single unit that sits inside the distributor housing. For use with a 12-volt negative ground system and features a Unilite module with a simple 3-wire hookup. Use the Mallory Promaster Coil for peak performance.
        Part Number: 9-26504
          I have indeed ran into such a situation. you
          should get your best performance around 30degrees of
          total timing.(asuming its a small block ford or chevy.
          Marine distributors only have a mechanical advance.
          Check to make sure the flyweights in the distributer
          are free to pivot. Your initial timing should be
          around 17 degrees or so. you should have your full 30
          degrees or so at about 2500 rpms. You really need a
          adjustable timing light to check this, you can measure
          around the ballanceer and do the math to get your 30
          degrees and make a mark. Now if you dont want to do
          all that effort adjust the timing forward till you get
          it to run good, get some heat in the motor and shut it
          off. if it starts hard like its laboring then you have
          the timing too far. Its rare to here spark knock in a
          marine engine because of the cooler operating temps.
          Now one other thing Electonic iginiton needs to run
          off of a full 12 volts. that meens you need to get rid
          of the dropping resistor most point systems use.
          during cranking point systems use full 12 volts, after
          the engine starts it drops to 6-8 volts. because of
          the dropping resistor. On GM marine engines the
          dropping resistor is actually the tan wire that feeds
          the coil(+) side. it is about 3 feet of high
          resistance wire
            Something new to report on the Mustang's points replacement...
            We worked the boat hard for several hours this weekend and as the engine picked up a lot of heat it would start to miss-fire. After it cooled a little - running slow 1500 or so RPM - it would clear up and run smooth again. We use the Mustang a lot and until this event it has been running very good.
            So, I'm thinking this is a symptom of just a little too much timing advance. I'm going to back off a few degrees and see what happens. It may be hard to replicate, but we'll see.
              YOur coil might be showing its age. remember a 12 volt coil needs a external resister or resister wire unless its the "internal resistance type" the next time your engine misses touch the coil to see how hot it is getting. dave.
                That's a good thought. The coil is a farily new, but that does sound like a good place to check. Farily new is relative, maybe 5 to 8 years.
                Ballast resistor is in place.
