Hull drainage
  • Hull drainage
    I keep my 21' in the driveway and it slopes down to the road. Now because of the shape of mako hulls it seems no matter what I do the boat appears to be level. This presents a problem when washing it down as I cannot get all of the water out of the bilge. I have my wheel jacked up as high as safely possible. Is there a safer solution other than buying a big jack to lift the front end high enough for normal drainage?
    Not that I know of, unless You use a floor jack and a big block to set the toung jack on.
    I went and got/made a big Oak block. Huricane Ivan helped. There was plenty of wood stacked by the road. I just took my chainsaw to a piece and squared it up.[]
      CHANGE HOUSES!!!!!WHERES YOUR PRIORITIES!!!![:x)]
        Yeah, I suppose I do need to find another block. I have a 4 x 6 now. Bobby, sorry I forgot to return your torque wrench today. I will get it to you tomorrow.
          Troy,
          When I put my 191 in my boat stall there is always about 1/2 to 1 gallon of water left in the bilge.
          My solution is I shove a strip of a bath towel in through the bilge drain. Make sure it is in the water that is left in the bottom of the bilge. This will wick the water into the lower hanging section of the towel. Within 2 days the bilge is dry as a baby's bottom.
          Give it a try. It might work for you.
            Larry, that is a great suggestion. I will give that a try. Never even thought of it.
              I'm guessing turning the boat around is out of the question... or you would have already done that.
              I had the same problem and just stuffed as many cinder blocks and 4x4s as it took to get the water to run out.
              I guess hanging one of those shammies into the bilge from the inspection port would help suck up some water.... that's a good idea! []
                I don't mind doing the blocks it's just a pain to have to pull the jack out everytime I put the thing in my driveway. I will give the towel a try.
                  Larry, so far that seems to be working. The towel is slowly getting wet all the way down to the bottom. I will check it in a couple of days and see where it's at. Thanks for the suggestion.
                    Great Troy, let me know how it works. It has always worked for me. Its a good use for an old tattered towel. Just make sure it is long enough to get to the lowest point of water in the bilge. I usually leave about a 12-18" hanging down.
                      Second Larry's idea, Hammertime turned me on to this little trick.....it works.
                        Have you considered a small submersible pond pump to drain the last of the water out?
                        A government big enough to give you everything you want is a government big enough to take from you everything you have. [br]Northport Occupied NY[br]1989 191 w/120 Evinrude
                          I thought of an extra bilge pump but not a pond pump. I will see how the towel works, cheap enough!
