Fuel system
  • Fuel system
    Just bought a 79 25" mako and it has 2 fuel tanks can anyone tell me how much each tank holds? and what is my fuel burn going to be with a 1990 johnson 225, we disconected the oil injection and are mixing oil straight to the tank?, can't figure out where the forward tank is? I think that the aft tank is under the rockett launcher. I went to the owners manual links for 70's mako 25 and that manual looks nothing like what I have got? any help
    Time Flies 79 25\' mako Marathon Florida
    There are several 25 owners on this board, Hang tight and you will be overwelmed with good info, BTW, welcome aboard, and can you also include your location in you signature line so we know where to send you for parts and such. heck who knows we might be neighbors!! dave
      Orginally posted by Time Flies:
      ...what is my fuel burn going to be with a 1990 johnson 225, we disconected the oil injection and are mixing oil straight to the tank...
      My father's boat (1978 Whaler Revenge 21') has a Johnson 225 ~1991. For a round trip to our duck camp (inland/marsh waters with heavy load), we usually burn ~14 - 16 gallons (Premium unleaded). Trip mileage is around 32.5miles. This would yield about 2.16mi/ga.
      Good move on removing the oiler. These will eventually fail. However, some people simply replace them with new. The only problem with complete removal is the damn buzzer will go off when under a heavy load at high RPM's. You have to bypass the oiler sensor harness to stop this.
      -Pat
        the '76-'77 Mako CC had the 86 gal tank stock and and optional 36 gal tank. The larger tank (aft) is under you hatch below the helm, the smaller tank is forward of the larger tank.
          So when you are filling the forward port on the port side, that is the forward tank right the reason I as the fuel guages may be marked back wards? also the fuel sender under the rocketlauncher is that the sender for the aft tank?
            Yes. Yes. Yes......
            Of the stock 25'ers from '76-'79 with the twin tank setup, I've never seen an access hatch to the forward small tank. The sending unit behind the console will be your aft tank. The forward tank sending unit will need a hatch cut for access if necessary.
            Do you have a valving system to select which tank you use. Is it at the filter?
            Not sure about the fuel gauges being backwards. Guess that has to do with how you look at it. In the morning the guage on top might swap ends to the guage on bottom after the icechest is empty... [88][88][]
              ok just as i thought valves to switch the tanks are under the center console and the fuel water seperator is in the back before the engine, the aft tank guage is reading full? I know it is not yet if it is the 78 gal and the forwad tank guage is half tank as I have only been bringing her 6 gal juggs from the gas station and mixing, the forward tank is full and venting overboard oops!
