Switches for the console, Eddie
  • Switches for the console, Eddie
    Is it possible to find out the supplier of the switches in white, Eddie?
    I got them directly from Carligswitch... It took me nearly a year to get through their non-distributor red tape, but I managed. They have a few distributors around the country. You might check out their webpage http://www.carlingswitch.com
    These are the switches I used:
    http://rocker-switches.carlingtech.c...switch__19.asp
      Thanks I like the white skeem with the white gauges. I had not been able to locate the switches. I will try to contact them today.
        You could try Mouser Mlectronics. Here is a link to the contura switch spec sheet, 1093.pdf.
        http://www.mouser.com/index.cfm?&han...*&N=0&crc=true
        I went on www.mouserelectronics.com and searched "contura switch". They sell the switch body separate from the actuator (the actual switch part you see on your switch panel). The actuators are around $1.80 and the switch body is around $12. You may be able to buy just a white actuator of you already have contura switches. Eddies switches look like style "C", but there are other contura styles there as well. The catalog specifies only black but I bet they can send you the white ones or grey ones if you call and ask them. Hope this helps.
        Steve[br]Scituate MA
          I ordered mine special with white lenses in the actuator and red LED in the switch housing. They really are first class. I want to say I paid about $15-16 per switch.
            Thanks, I was just checking out that site and found that there is no minimum order required. So I guess thats not that bad. Heck some of the Cole Hearse switches cost double that amount for their less than perfect stuff..
              The mousier operation was first rate on the phone. You are able to speak to a human and the human knew what he was talking about and was very patient with explanations. He actually pulled up this site. The white covers are only avaliable for special order.
