I am trying to decide if I should put the bow rail and console rail back on Annie II or not?
It does serve a purpose and will look sharp when the rubrail and Stainless Steel insert go on - (need warmer weather and no rain).
What do you guys think?
Annie II Update:
Am making progress on Annie II, began wiring last night. Motor is hung,New instrument panels are made, guages and switches are installed, teak is refinished and installed, bilge pumps and switches are installed, 2 cycle tank and filler pipe installed, fuel tanks re-plumbed with individual shut off valves,fuel senders are wired, S/S thru hulls are in, scuppers are plumbed, live well is plumbed and new valve installed,bow and transom lights are installed, cleats and rod holders installed, fuse panel, circuit breaker, ground buss and battery swicth all installed, dynaplate gound plate installed thru hull for ground attached to fuel tank grounds and SS thru hulls. F/F Chartplottrer, CD Player and VHF will be dry fit and mounted tonight. When wiring is done, I'll be able to begin rigging...
Need about three solid days to finish. With the weather we have been having, it'll take me three weeks to get 3 good days!
Annie II Update:
