outboard question
  • outboard question
    I am a relatively new owner of a mako 17 with a 88hp johnson outboard on it. Recently the waterflow coming out of the "pee hole" has reduced to a trickle. I don't know much about outboards or even boats being my first boat and all. I do know that the water circulation is used for cooling and I might be in for a major problem. The circulation increases with the throttle but still is not what it used to be. Could something be clogged in the system. I am a mechanic by trade, but jet engines are much different than old outboards. I would greatly appreciate any info, input or suggestions that come my way.
    panama city, Fl[br]1978 mako 17
    I'm not sure what maintenance you have done in the past, but I would replace the impeller and thermostat(s) for starters. It could also be a blockage in the hose leading to the "pee hole" you may want to pull the hose and take a look.
    That's where I would start.
    David M
      Good advise,dtmackey, You should get a hold of a service manual, I think you might even find one at the library. dave
        Jamie, your "pee hole" is nothing but an indicator that your impellor is working and only shoots out about 5% of the actual water. The other 95% of the cooling water exits through your lower unit, most likely through your prop. You probably just have something clogged in your "pee hole", maybe a stone? haha. SO pull the hose to it and poke a paperclip up there or blow it out with compressed air. If that doesn't do anything, it's probably a bad impellor if you haven't changed it in the past couple years
          Take a piece of 100 lb leader material and fish it up the pee hole and work it around a bit and the stream should return to normal. By the way you should change the impeller at least every three seasons.
            Impellors are cheap. Cooked engines are expensive. I have to do some research and find out who said, "A wise man learns from his mistakes, but a brilliant man learns from the mistakes of others".
              If you dont know when the impeller was changed then I would suggest you change it anyway. Preventive Maintanance is always a good thing.
              A government big enough to give you everything you want is a government big enough to take from you everything you have. [br]Northport Occupied NY[br]1989 191 w/120 Evinrude
                Pull the pee hose from the block and then Rotor Route it. That way your not pushing a obstruction back into the motor to reclog it at a latter date. If that doesn't clear it up. Then I suggest a "Whole" waterpump kit. not just an impeller.
                That way you will have a baseline on the motor.
                  you can get the water pump kit at panama marine for $53 , I just replace mine last week and what a difference it made
                  Richard[br]Panama City,FL[br]Currently Looking for a MAKO[br]America needs Obamacare like Nancy Pelosi needs a halloween mask[br]
                    Thank you all for your advice. I am going to make sure i don't have anything stuck in the water tube and get the waterpump kit. Is the waterpump/impeller located in the engine compartment?
                      Its in the lower unit. Drop the unit and the impeller is on the drive shaft inside a housing.
