Log In Difficulties
  • Log In Difficulties
    For the past week or two, I've had occassions, where I logged in even getting a message back, confirming that I was logged in, then tried to answer a post, only to discover I wasn't logged in, and had to re-type everything I had just typed, as it was GONE !!!
    Tonite, I logged in four (4) separate times before actualy being logged in.[B)][B)][B)][B)].. Usually only takes a 2nd try...
    What UP[:0]?
    No problems here, I stay loged in, dont know maybe a little desert sand in the system hehe. P.S. your new digs are awsome. dave.
      Either that, or it may be because my internet connection is through the local library[:I]... Could be getting all sorts of glitches from the systems that the kids get to play on all day[B)][:0][]...
      As soon as I get to move into those new digs, I'll get to quit driving to the library to use the internet...[8D][:x)][:u][88][][][]
        Do you like cookies? Hey by the way, my Jeep crapped out on me a couple of days ago. I got it restarted and thought that I would wiggle some wires and wiggled the "Sync" Sensor wire (the one on the distributor) and the engine cut off like I turned it off. I pulled the connector apart and reset it and the damn things been running fine since. Make sense?
        72\' Mako 22\'[br]NoNeck, VA
          Like Cookies? OH YEAH !!! My favorites are Snickerdoodles.[][][][][][].
          ANY of the sensor wires and connectors which get broken, or corroded/dirty enough to increase resistance, will cause the problems you've been chasing. THUS, cleaning the connector and having a motor that runs better, makes PERFECT sense.
          NOW I'd suggest you go to your local auto parts store, and purchase a tube of dialectric compound (electric grease), and begin using it of ALL of your wiring connections that you work on, as insurance to keeping them clean & functioning good. ESPECIALLY if the connector is working in a "hostile" (water/heat, etc) environment.
          Good Luck...
            I just had a problem. Same deal. Type your stuff and go to enter it and it say's your not logged in, which deleat's what you wrote.
              HeHe You know what Snickerdoodles are out in Arizona?
              My brother Bill will not eat them. He sat down and ate 65 at one sitting that Mamaw [my grandmother] had made. The whole can. HeHe.
                I've had that problem before where all of a sudden your not logged in anymore. It's like something just kicks you off after a while.
                It hasn't happened lately, though.
