My boat and trailer fully loaded weighs in about 3300 pounds. I have a 2004 Jeep Wrangler with a tow capacity of 2000 lbs. I believe this is more of a wheel base issue than a weight issue as the Wrangler Unlimited which is the same vehicle only a longer wheel base is rated for 3500 lbs. I will not be towing long distance, maybe three miles most and off course with a 90 inch WB I will be going slow. I would prefer to go with an itegrated bumper set up in order to retain the ground clearance. The Jeep is a Sport with the larger tire set up with a 4.0 6cyl and a 5 Speed Trans. The trailer does have brakes
Any thoughts would be appreciated
