Kicker outboard for 19'?
  • Kicker outboard for 19'?
    Is there a best way to mount a kicker or "take-me-home" outboard on a 19 footer with a 140hp? How much horsepower is likely to be barely adequate? How much seems wise? Is the peace of mind of having the back-up worth the down-side of the extra weight? I need your thoughts on this because, left to my own devices, I can complicate almost anything.
    Thanks!
    Win
    You will not regret haveing that extra assurance of a get home motor
    I also use mine for troling as I troll for salmon hours on end.
    I dont quite remember if the 19 has a strait across transome or not.
    if it does then this is what I use on my 21. (25 merc.) you can get away with as little as 10 hp. I like the 25 because I can find them cheep up here and they troll like a dream. I have had 5 of these motors and have had good luck with them. I hook them up remote. they have a charging system. electric start. will troll all day on a gallon or two of fuel. If you have a notch transom then you need a aux. bracket mounted on either side. If you look in the pic you can see my steering setup. This even allows for indepentent tilt of either motor. dave
