Have just bought an 85 258. It has two fuel fills on the port side as well as a switch that says aux pump. Both valves are open. I need a manual or some input from someone who can help with info. How much fuel does it hold can either valve be turned off. The boat seems a bit bow down but both gagues are working and indicate full. I see no water in any of the foam. It has a 1999 200 Johnson w/carbs and only about 100 hrs. It turns 5200 and gps says 38.5 mph and 26 at 4000. Does that seem about right. The owner is deceased so no help there. Any help is appreciated.
Dave
Dave
