Gelcoat Info and Info for epoxy vs. polyester
  • Gelcoat Info and Info for epoxy vs. polyester
    http://www.westsystem.com/ewmag/22/polyester.html
    http://www.westsystem.com/ewmag/22/fiberglass.html
    http://www.westsystem.com/ewmag/proj_repair.html
    Some of us do it yourselfers might find this of use.
    Totall agree. That is my bible. I am a big believer in Epoxy resin. If you are going to gelcoat over the epoxy repair/laminates you need to use West System. If you are just painting, then you can go cheaper and use some of the more economical epoxy resins. The economical epoxy resins in many cases are much stronger than West System (If you look at the spec sheets) but the fact that you can gelcoat over West is its main selling point for me.
    I used some epoxy resin in the house today. No fumes or smell whatsoever.
      Hey Ring, In what cases are other cheaper epoxys stronger ? Then I could save a little dough on other applications.
      Thanks, Ricky
        I've never used epoxy in repairs but I'm interested in doing it on structural stuff. From what I understand, the reason gelcoat won't work on epoxy is the amine blush, but if you wash it off with water it will cure. I've also heard that West System epoxy has more anime blush than most epoxies. So if gelcoat will work with West System, shouldn't it work with other brands, after all, it is a mechanical bond and as long as the blush is washed off it will cure.
        1973 Mako 22[br]Bahamas
          Here is a quick comparison between the specs of West System's 105/205 (their regular 5:1) and Several Epoxy resins from Fiberglass Coatings Inc.
          West Systems
          Shore D Hardness (PSI) - 83
          Heat Distortion ( Degrees F) - 118 degrees
          Tensile Strength (PSI) - 7846
          Tensile Modulus (PSI) - 408,000
          Tensile Elogation (%) - 3.4%
          Flexural Strength (PSI) - 14,112
          Flexural Modulus (PSI) - 461,000
          Compressive Strength (PSI) - 11,418
          FGCI 5:1 Epoxy
          Shore D Hardness (PSI) - 80
          Heat Distortion ( Degrees F) - 130 degrees
          Tensile Strength (PSI) - 14,600
          Tensile Modulus (PSI) - 497,000
          Flexural Strength (PSI) - 17,700
          Flexural Modulus (PSI) - 697,000
          Compressive Strength (PSI) - 14,600
          FGCI 3:1 Epoxy
          Shore D Hardness (PSI) - 78
          Heat Distortion ( Degrees F) - 128 degrees
          Tensile Strength (PSI) - 9850
          Tensile Modulus (PSI) - 436,000
          Tensile Elogation (%) - 5.9%
          Flexural Strength (PSI) - 17,500
          Flexural Modulus (PSI) - 552,000
          Compressive Strength (PSI) - 13,300
          FGCI 2:1 Epoxy (what Bobby uses)
          Heat Distortion ( Degrees F) - 13 degrees
          Tensile Strength (PSI) - 8800
          Tensile Modulus (PSI) - 390,000
          Tensile Elogation (%) - 7.2%
          Flexural Strength (PSI) - 14,900
          Flexural Modulus (PSI) - 441,000
          Compressive Strength (PSI) - 12,300
            When I called West, they told me to sand after it cured, then wash with soap and water and you'll be able to topcoat with polyester gel-coat.
              Correct... Thats what I do.
                I also prefer Epoxy Resin's mainly to avoid the pungent smell of the Resin and toxicity of the Styrene harnder.
                Epoxy I think is a lot easier to work with as well, once you have the mixing pumps and all.
                I only used West System Epoxy, do the other Epoxies smell badly? Or do all have that minor "epoxy smell" like West System or Flexcoat for rods?
                Jones Inlet, Long Island
                  All epoxy resins are very low on smell. I used the FGCI epoxy insid the house last weekend to do some touch-ups to the fiberglass coulmns in the foyer... Even the wife never picked up a bit of oder from the stuff.
                    With the FGCI epoxy and others, besides 5:1 being stronger than 4:1, 3:1, 2:1, what are the differences in them? Is the viscosity different or the drying time? I think I'm going to try the FGCI epoxy but not sure which one to get.
                      The 5:1 and 4:1 from FGCI are very strong resins. But teir working times are super short. I mean that you literally won't get 6 minutes out of a batch... Thats not near enough time to fdo anything. Their 3:1 and 2:1 are better for working time.
                      Jason Thornhill used a 3:1 epoxy from a local supplier and had excellent working time.
                      West System with the tropical hardner (209) gives good working time as well. Their 205 hardner is too fast as well.
                      All this is in our warm and sunny southern states. In cooler climates the fast hardners might give a little more working time.
                        Yes to the last statement, up here I only use the fast hardener, it takes for EVER otherwise. It also works for quick fixes. dave
                          I used 205 yesterday 81 degrees I was humpin to get 10 minutues work time. Today I used 206, got about 15 20 minutes at 85 degrees.It worked great, no humidity
                            Anything over 85 degrees or so I use the 209 hardner. Its a 3:1 and uses different pumps. It'll give great working time in temps and humididty both in the 90's.
