224Live well
  • 224Live well
    My 85 224 live well always has water in it ,due to the design.I guess. Have any of you tried any check valves or one way scuppers to eliminate the water. I would only like to fill it with the pump,all other times I would like to keep it empty.
    Bob
    Yes. In alot peoples opinon that was a poorly designed bait well at best. At worst you could fall into it when the hatch is off and break a leg. I hate them because they are a pain to clean...end rant.
    Many years ago my Dad put an in-line ball valve forward of the thru hull (which is the pick up for the baitwell) to prevent it from filling and if we wanted it filled then prevented if from draining when we picked up and ran.
    Cliff
      Heres what I did with my infloor baitwell, I sealed it up and am using it for a water tank supply for the washdown pump. I have 2 inline valves, one for the tank and one sucks off the bottom thru hull. When I pull the boat out of the river I can quickly wash the scum off before the 15 gallons or so drain out.(or close the valves and keep the water in till I get home)
        My 224 has a ball valve in it, I just naturally assumed that it came that way from the factory.
        This seems to work well to keep the sea water, no easy way to keep the rain out. I keep a hand bilge pump on board and just pump it out after it rains, or after I wash the boat.
        This is easier than crawling around by the motor when the boat's on a plane and opening and closing the valve.
          On my 224, I got so tired of "fussing" with a moldy stinky wet mess all the time[B)][], that I simply pulled the pumps and lines off, and now use it for a battery box for the three batteries for my 36V trolling motor[8D][].
          OB1
            Ob1,
            How did you prevent rain from getting in?
