set up new trailer
  • set up new trailer
    this weekend I plan on setting up new roller trailer
    for mako 191. I am switching over from a bunk trailer.
    any advise on roller positioning would be appreciated.
    thanks in advance
    Capt Bobb
    Mako 191
    Boston/Cape Cod
    Not on rollers but here is mine.
      The rear rollers should be about 4 to 6" from the hulls transom.You may have to adjust the winch stand to fit the new position.This is my 17 still under construction,has 20 rollers,I hope this helps.
        Bunks are better for the boat- my .02
          Unfortunately, around here on Cape Cod and north shore the ramps tend to be very steep, making the bunk trailers very hard to use.
          HD
            Yea and the boat drains better if you leave it uncovered and it rains front is tilted up better on the coss members.Always the same centering,Ive have both one expensive and one cheaper,If you always wash them down after every use,they'll
            last you.I got this trailer out of necessity,at the time I could't find one to fit my boat, bunk or rollers. I think these 17's are built heavier than most 17's so the weight to length ratio is the difference.I would think they're a little easier to find for the 19.Good luck
              Beautiful boat Larry. []
