patching up screw holes
  • patching up screw holes
    The previous owner moved the tannsducer 2 times
    on the transom of my 191. Currently the old screws
    are in the transom with 4100.
    I plan on painting the bottom over the next few weeks.
    My plan was to pop the screws, enlarge the size of the holes
    slightly and pump the West System Expoxy into the holes.
    Good or Bad idea. Thanks in advance for taking time to
    answer. This is a great forum with knowlegable members
    without attitude.
    Capt Bobb
    Mako 191
    Boston/Cape Cod
    Your good to go.[]
      warthog5 sent me this link a while back. should help.
      http://bertram31.com/proj/tips/sleeving.htm
      John[br]Lafayette, La[br]
        that sounds good,but i always use 5200 for a underwater sealant.
        chip[br]1971 mako 19\' / 2013 Pathfinder 22TE[br]Panama City,FL[br]
          Thank you all for your advice.
          Capt Bobb
          Mako 191
          Boston/Cape Cod
            captbobb,
            I had the same exact question! I recently purchased a 1969 19' Mako from a family member who loved silicone anywhere and on everything. Currently, my boat is in Hyannis in winter storage and with the current forcast, it will be there for a couple more weeks. As soon as I pick it up, I plan on using the 5200 and pulling out old screws that are no longer needed i.e. old trans mount etc. and sealing them up. Even in the inside of the boat, over the years you can see where there were once rod holders screwed to the inside walls and are now open screw holes. Ideally, I would love to go through the entire boat and clean, bore and seal every hole I could which is probably what I am going to do before I launch this spring. Let me know what you decide on hole filling and how you make out. I probably won't get to mine until first week of April.
            Good Luck.
            69\' Mako 19[br]03\' Suzuki 115
