I'm having problems with my motos or teleflex? My motors (Mercury 225 efi 1992) are running good(APARENTLY)and they start fast and with good "tone". I suspect thet problem is with the teleflex.
Motor 1 dosn't run more than 1800 rpm in water at full trotle. When you move the shaft forward, you need to go more than half way to acelerate. Out of the water is the same but you get 5000 rpm (must be the absence of resistance, right?).
Motor 2 have good aceleration but, in fordward have a bad noice. Sound like the gear dosnt completly shift. When you runing in reverse, it works fine.
How can I adjust the tflex cables or find if I have a mayor problem?
