sending unit
  • sending unit
    On my 21' 1979 Mako, I have the standard mechanical type guage mounted on top of the tank which I can see under the center console. I would like to be able to convert that to a digital signal for my dash guage that came with my 96 225 Evinrude. I have called the manufacturer of the tank and they act like it cant be done. West Marine sells a capsule for this, but wont fit my sending unit bolt pattern. Anyone ever done this??
    [br][br]
    Get a flowscan or a navman fuel computer and REAllY know how much fuel you have. Cost diff b/t the sender and the navman probably isnt even that much.
      mitch mako 21 - I have had both - the simple mechanical and the electrical. For my money, if it's already working well and you have confidence in the mechanical gage (as I did for 20 years) use it and stop worring about complicating things. I now hate my electrical gage and this spring I am gong back to a mechanical gas gage. I hate, hate, hate the electrical set up. Simple is good on a boat. However, I do agree that a Flowscam or Navman fuel management system are great for a double check on how much fuel you have used and for exter trip data, like miles per gallon or gallons per hour etc. They are a bit pricy but well worth it when you need to know how much fuel you have left for the long trip home.
        Just went thru this, your gauge setup is made by rochester gauges out of texas, go to rochestergauges.com and you will find a conversion kit for your setup. or you can purchass a new gauge capsuel for the one you have.(mechanical) You probably have a
        6200 series gauge. It is the "senior" gauge. Part number 5002s00062.
        Thats the number for the replacement mech. style. the elect. conversion is also listed. There phone number is 1-972-241-2161
        Hope this helps dave.
          Thanks guys. I will call them and see about it.
          [br][br]
            Good fine Dave. http://www.rochestergauges.com/
            That one need's to go on the list.[]
            http://www.classicmako.com/forum/top...?TOPIC_ID=3176
