Easy Question for you experts
  • Easy Question for you experts
    I want to simply remove my bow rail, clean the mounting areas of old/non existent caulk and reseal with 5200 and reattach the bow rail. Can I reuse the old screws if they appear to be in good shape? I want to do the same with my old starboard and port bow side wall inspection ports. I assume this should be a straight forward quick project but I own a 100 year old house and "assuming" some home projects were simple has turned out badly in the past.
    Thanks,[br]JB[br]\'91 Mako 201[br]Oxford, Maryland
    Sure you can do that.[] If the heads of the screws are buggered, I'd replace them. If not use them again.
      Jdeerin - One other thing to consider if you want to replace the screws (to keep the boat looking orginial) is the age of your boat. Some of the newer guys don't know this, but all the older boats - '60's, '70's and into the early '80's used all SS slotted screws (don't know the exact year when they changed over). To my knoledge, SS slotted screws are no longer available in any quanities and now All the newer boats come with philips head screws. So, unless you find an old stash of the SS slotted screws, you will not be able to replace (assuming you have slotted) them with new ones. Hope this helps -
        Check out this place for your ss fastners.they have excellent service and selection.dave []
        http://www.boltdepot.com/dimension.aspx?cc=3&cs=44&cm=6
        85 McKee Waccamaw[br]84 Johnson 90[br]West Creek NJ[br] [br]
          Would not reseal the screw holes using 5200 -- I'd use clear silicone.
          5200 is too permanent, you may want/need to remove the bow rail later.
            Read here:
            http://www.classicmako.com/projects/...o_project7.htm
              Davexx...thanks for the fastener link...I have been buying seperately at my local marine store.. I knew I was getting my eyes gouged out !! but come on !! I'll be ordering in bulk right away..
              22 Tiara pursuit[br]Greenwich,Ct
                I buy SS fasteners from a local ACE hardware store. They have a great selection and the prices are very nice too.
                  I get a lot of my fasteners at our local ace also. They tease me when I come in " What ya building today, Noah?" dave
