hard steering
  • hard steering
    I find my 175 Johnson on my '73 22 steers well at idle or low speed, but as I whip her up it gets REALLY hard to turn the wheel. Am I about to bust the cable??? This is not so on another rivet boat (don't want to disgrace this fine site w/ a blasphemous name ) ahem!(tracker 17) cough cough! I own w/ a 50 on the back. If this is normal, OK; and I really don't want to go the hydraulic steering route. Any suggestions welcome. thanks, Mark.
    \'73 22 Mako Reedville, VA
    If the cable hasnt been changed in a few years you might consider doing so. You can buy a complete kit with helm and cable for a little over a hundred bucks if you shop well. This usually will restore the stearing to new. dave.
      If you plan on keeping the boat for some time then spend the money and go HYD (or keep replacing cables every 2 years). That way you'll enjoy the time on the water and not constantly be fighting with a stearing wheel the whole time. It's just my 2 cents worth after having both - the manual for my first 9 years (4 cables and 1 big T helm) and the SAME HYD system for the last 16 years. Do the math -
        I've been wondering if the little trim tab/anode is out of adjustment?
          My thoughts as well. That little anode can effect the steering quite a bit I've been told but a number of folks. Worth a look, Far cheaper fix as well.. Free is a good thing (sorry my wife is sych'd Martha's out of the pokey)
          SB
            Sounds almost like the same problem I was having with my Boston Whaler Montauk. The motor on that boat was not set up right on the transom. I raised the motor up one set of holes to take care of my hard steering. Once on a plane the trimming of the motor made it even better. If it was the tab don’t you think with cable steering that he would have a bad pull to one side or the other? Maybe not…….
              What does that mean?
              Is it light/easy when you turn into the rotation of the prop and hard the other way? Does the boat tend to drive port or starboard if you let it do its own thing?
              If you are running hard and fast with the bow up, then I think you are fighting engine torque and the weight of the boat.
              If you are running at mid throttle you might try adjusting the trim to see if you can lighten it up.
                Yep, shankiee and I are the same path. To much engine torque on the steering while under way it what I'd guess first.
                  hard steering:if the helm is difficult to turn at all times than it's usually a cable.if the steering is difficult and seems like it wants to turn one way and you're fighting the wheel than it's torque steer-try trimming the engine up does it feel better?? a good practice with cable steered boats is to trim the engine up till the steering feels light.a quick check is to tilt the engine up and look at the torque tab-on the omc/bombardier out boards that torque tab is not a zinc anode-see if it is in the middle if it's not than move it there.test run the boat see if it is better if it is than you're a genious you solved your problem.if the boat still wants to turn than move the tab in the opposite direction of that pull just a little at a time untill you get it right.the bolt that secures that tab will loosen due to the prop wash so use a little dab of blue lock tite on it DO NOT USE THE RED LOCK TITE IT WILL NOT COME OFF WITHOUT HEATING IT.you guy with yamaha and merc out boards should do the same thing-ever notice that the zincs are loose -that's why.the hydraulic steering is the only way to go-it's expensive but well worth it. a good practice with the cables is to lube them with corrosion block grease-pull the cable out of the tilt tube get a brush that chucks into the drill run it through the tube to break up any rust in there spray it with crc don't use wd40-crc is the only product that i am aware of that actually neutralizes salt!! than pack that tube with the corrosion block grease-use that stuff it's worth the extra moneyand apply that grease to the cable while you are putting it input the end seal on the opposite side this will avoid water entering the tilt tube and you're done!!
                    Great contribution Jawz, what you said sure makes sense. dave
                      Does sound like Jawz has been around a boat or two.
                        A 12ga shootgun brush work's well for this.id="size2">
                          wart hog - i forgot about you southern boys and the guns you boys have-that's a great idea !! another thing that makes the steering tight -i mentioned this previous-is the bushings on the top and bottom of the tiller pin.when the salt water evaporates you're left with salt which will wick moisture-this will pry into the bushings causing them to become tight-result hard steering.with that it's important to keep the engine lubed at a regular rate-just use a quality grease in the gun and give the fittings a shot twice a month!!
                            We started this out with:
                            Originally posted by mchar
                            my '73 22 steers well at idle or low speed, .
                            Mark, you got some great tips!
                              OK, see what happens when you go to sleep - thanks for all the replies...I don't have tabs on the boat, it steers hard in both directions, and gets harder as my speed goes up. I haven't tried trimming up the motor while running yet. I didn't know it was every 2 years to replace cables...that is not going to be easy to fish that cable..I'd rather sawsall the transom and those lousy fish boxes out! Mark
