painting Interlux VC Performance
  • painting Interlux VC Performance
    Do any of you know if you can paint Interlux VC Performance paint over the 2000E barrier coat? I was planning on painting 2000E followed by the VC Performance but now I am not sure if the two are compatible.
    How about Imron over the 2000 E???????????
      I recall seeing all the info on VC and compatibility on the Interlux website.
        VC Performance Epoxy is a two part Teflon® bearing epoxy that has a hard, slick finish ideal for use on the underwater surfaces of high performance powerboats and racing sailboats. Teflon adds lubricity and eases wet sanding and burnishing. VC Performance Epoxy's hard, stain-resistant finish is also ideal for rack-stored and trailered boats or boats that are kept in the water not requiring antifouling protection. VC Performance Epoxy has no antifouling or foul release properties.
        PRODUCT INFORMATION
        Colour V127-White
        Finish Semi-gloss
        Specific Gravity 1.07
        Volume Solids 45%
        Mix Ratio 1:1 by volume (as supplied) , Converter/Curing Agent - V128
        Typical Shelf Life 2 yrs
        VOC (As Supplied) 550 g/lt
        Unit Size 1 US Quart 1 US Gallon
        DRYING/OVERCOATING INFORMATION
        Drying
        50ºF 73ºF 95ºF
        Touch Dry [ISO] 3hrs 2hrs 2hrs
        Immersion 7days 4days 3days
        Pot Life 6hrs 5hrs 4hrs
        Note:Maximum Immersion Times are as follows: 10-35°C/50-95°F - 60 days
        Overcoating
        Substrate Temperature
        50ºF 73ºF 95ºF
        Overcoated By Min Max Min Max Min Max Min Max
        VC Performance Epoxy 6hrs 24hrs 5hrs 24hrs 4hrs 24hrs
        APPLICATION AND USE
        Preparation BARE FIBERGLASS: Begin by scrubbing well using soap and water and a stiff brush. Rinse with fresh water. Wipe with Fiberglass Solvent Wash 202. Sand with 80 grade (grit) paper. Wipe with Fiberglass Solvent Wash 202.
        CLEAR EPOXY: Begin by scrubbing well using soap and water and a stiff brush. Rinse with fresh water. Wet sand with 80 grade (grit) paper. Wash down with fresh water. Wipe with Fiberglass Solvent Wash 202.
        BARE METAL: Sandblast or grind to bright metal finish. Immediately apply Viny-Lux Primewash 353/354 thinned 25% with Viny-Lux Solvent 355. Allow to dry for 1-24 hours.
        Method Apply 3 coats of VC Performance Epoxy. VC Performance Epoxy is designed for spray application but can be applied by brush and rollers.
        Hints Mixing Mix base and curing agent thoroughly at the specified ratio. Allow 45 mins at 50°F/10°C and 30 mins above 77°F/25°C for induction.
        Thinner Reducing Solvent 2316N.
        Thinning Thin, if necessary, after induction.
        Cleaner Bare Fiberglass - Fiberglass Solvent Wash 202. Epoxy - Fiberglass Solvent Wash 202.
        Airless Spray Pressure: 142-170 bar/2100-2500 psi Tip Size: 0.48-0.53 mm/19-21 thou.
        Conventional Spray Pressure Pot: Pressure: 3.44-4.08 bar/50-60 psi - gun pressure; 8-15 psi pot pressure. Tip Size: 1.4-1.5 mm/55-60 thou. Siphon Cup: Pressure: 3.06-4.08 bar/45-60 psi. Tip Size: 1.4-1.5 mm/55-60 thou.
        Other If fairing is necessary, use Interprotect Watertite between 1st and 2nd coats of VC Performance Epoxy and then apply 3 coats of VC Performance Epoxy over the Interprotect Watertite.
        Some Important Points Product temperature should be minimum 10°C/50°F and maximum 29°C/85°F. Ambient temperature should be minimum 10°C/50°F and maximum 35°C/95°F. Substrate temperature should be minimum 10°C/50°F and maximum 35°C/95°F.
        Compatibility/Substrates VC Performance Epoxy can be applied to gelcoat, bare fiberglass, epoxy and properly primed metal. Apply to clean, dry, properly prepared surfaces only. VC Performance Epoxy can only be applied over two component products that are specified for underwater use. If there is any single paint (such as antifouling paint) on the surface, it must be removed and then proceed as with bare surface.
        Number of Coats 3-4 as needed
        Coverage (Theoretical) - 200 (ft²/Gal) by spray
        Recommended DFT 3.5 mils dry
        Application Methods Brush, Roller, Airless Spray, Conventional Spray - Pressure Pot or Siphon Cup
          Yep, sure can.
