Any opinions on the pros and cons of Bennet and Lenco trim tabs?
Bennett vs Lenco Tabs
i have installed numerous trim tabs on customer's boats and i gotta' say the lenco tabs are much easier to install earlier units had a few problems with actuators however i have not seen a problem with them for quite a few seasons now.it is really a matter of preference.when installing trim tabs make sure to use the correct size and on larger boats 23 and up you want the biggest tabs you can fit-don't go overboard though example-don't use 36" tabs on a 23' boat. next size up is gonna be much better.they will help you keep the bow down to cut through a wave just beware of the spray!!!
I think that they are both great tabs, and you can't go wrong with either. Customer service is great from both. I think that I am going to go with lencos simply because there is no fluid reservoir that i have to find a place for. Less parts are easier on my brain. I have enough stuff that I need to find a place to put.
1975 23\' Tampa,FL
Thanks everyone for your replies. Very helpful. The 230 I'm starting to work on has old Bennetts which are too small and I don't know if they're actually in working condition. Since I'm gonna replacece them as if there was nothing there, your opinions are very valuable. I'm thinking 12" x 18" since I'll be getting a single engine.
If Bennetts fail they're supposed to retract with the pressure of the water, do you know what happens to Lencos if they fail? Will they just stick and leave you running trimmed?
If the whole boating industry followed what Bennett does. Especially with Tom aka Tabman. You would not hear the horror stories that are around the industry.
Granted Lynco's are easier to install, but Bennett's are going on my boat.
I'm not sure if the lynco's have made improvment's as Jawz say's. I've heard a lot of them had troubles. This may have changed?
Thanks for your input Bobby. Seems like Bennetts are less expensive too.
BTW got the Armstrong deck plates today. They are tough cookies. I'm alittle bit worried about the handles on the one I'm putting on the cockpit floor, but let's see how the hold on to heavy traffic.
Cape Horn uses Armstrong's on their deck's from the factory.
A little more about tab's. You guy's know my boat is a 23ftr. If your space for tab's is limited, as in my case with hanging twin's on it.
The "Batwing" style tab will give you the same effect as a little larger tab. I actuall went with the Tournament Tabs as opposed to the M120's They are the same size, but I wanted the tab's to be Black.
This is a 10X12 tab, but it's "Batwing" style gives the same effect as a 12X12.
I removed the 12x12 Boat Levelers that came on my boat (too small) and replaced them with 24x9 Bennetts.
From personal experience, Bennetts get my vote.
I've got 24x9 Bennet's on my puppy and they work great. Get the rocker switch though. I had the gyro type and hated it.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
With those tabs, I've always felt like I had backup steering options. I can literally steer the boat on plane with the tabs. []
I'm looking foward to trying my Bennett Auto Tab Control.
You run the boat on smooth water adjust the attitude of the boat with the rocker switch's. Once the boat is riding correct you push both buttons on the Auto Tab Control. This zero's it out. Then when your running you just turn it on and it seeks that zero point all the time.
No matter if you have a wild Indian running around the boat. It auto adjust's for that zero point.
