Is the Navman Fuel Mgt System Any Good?
  • Is the Navman Fuel Mgt System Any Good?
    Does anyone have any experience with the new Navman fuel management systems? They have a 2 inch LCD readout gage (that sell for about $150) that would fit into an existing hole on my CC dash. I hate the idea of drilling a new 3+ inch hole for the more expensive Flowscan system if I don't need to. Any comments would be appreciated
    I installed one on my previous boat. For the money you can't beat it. Easy installation and very accurate from experience.
    \'89 Mako 250 Cuddy[br]Stratford, CT
      I too have used the navman fuel system although it was part of the gps. It works great. Keeps track of how much your using. its more acurate as a fuel gauge than the factory gauges. You just have to remember to let it know when your adding fuel. dave.
        Hammertime has one. It need's a new tranducer on it right now. I bought the 3100 for my boat. It also uses the 2 1/16in hole, but it is wider on the console. I like BIG numbers. Easier to read for these old tired eye's.[]
          on my own boay i installed the fuel counter up grade to my navman 5500 it works very well.i have installed the counter alone on a few customer's boats and i can tell you that any navman product is very high quality and reliable!!
            I have one for my Navman GPS Chartplotter and 95% of the time I am on the fuel page. As others have stated, for the money you can't beat it and I haven't had any problems with the fuel part of the system.
              Can someone please explain the install on the transducer. I thought I read somewhere that is has to be installed in a vertical position - I could be wrong. I can't think of how I could do that on my rig.
                The instructions call for a vertical mount, fuel flows in the bottom up thru the sender and out the top. They say this is the best way to get a accurate read. dave.
                  I made a circle in my fuel line and then used large wire ties to secure it to the side and keep it from vibrating. When I get my boat back I will take a picture and post it.
                  Also, you must use the plastic clamps that come with the sending unit. Do not try and upgrade to metal hose clamps as it will not work correctly.
                    Thanks guys.
                    Sailor, I'd like to see that picture if you get a chance.
                      I like mine, accurate to a couple gallons.
                        ALL - Great to have this board - Thanks for all the good feedback - Guess there is no problems with this model and it looks like I will buy one for the boat.
                        Sailor - you said that you must use the plastic clamps that come with the sending unit and should not use metal hose clamps as it will not work correctly. Could you help me understand why this is?? According to what I read (I think it was on their web site) the system inside the transducer uses a small lazer to count the revs of the turbine as it turns from the gas stream flow. Don't see how SS clamps could effect this but I will do what they say to get the best out of the gage.
                          I believe the problem is that the clamps distort the line and thus cause a disturbance. There was a big discussion on the problem over on THT last summer and everyone reported that once they went back to the little plastic push on clamps that came with the unit the problems went away.
                            OK. Good and thanks for the heads up as I would have been one of those guys the would have gone directly to the SS clamps without even thinking that I could be creating a problem.
                              I am on my 3rd season with mine and am very happy.
