easier waypressurize the vent system by removing the vent hose from the fitting pressurize the tank to 3 psi an dit will flow from the feed line to the engine.the fuel will have to be disposed of at the appropriate waste handler!!
wish I had that 100 gal of fuel for my old John Deere, It would be proud to burn it up for you. But I live way up north so thats not to feesable.[] dave.
The City of Houston has a facility that will accept 25 gallons a week if you are not a buissiness. we took the 100 gallons from my 254 tank replacement to the ranch and used it for clearing brush fence lines etc. it was a fun ride pulling the flats boat and a bed full of fuel 350 miles.
The safest way is to disconnect the vent hose at the thruhull fitting and hook up a air compressor-low pressure then disconnect the fuel line and use the pressure to slowly push all the fuel out into a container,it took about 30 minutes to drain one of my saddle tanks this way.
not a good idea to use an electric pump in that manner sparks and fuel vapors dont mix very well safest way is the way i told quite a while ago about pressurizing the fuel tank via the vent.also remember to ground all tanks
If you use air pressure on a tank remember that there is a lot of area on the inside tank walls and a very small amount of air pressure (pounds per square inch) can create very, very large forces on all of the walls of the tank pushing it out. Think about it this way - at a low 10 psi over a 3 sq ft area or 144sq inches per sq ft and most tanks have way more area - so 3sq ft x 144inchs per sq ft = 432 sq inches x 10 psi = 4320 pounds of force. That's over a ton of force on the inside of your gas tank pushing outwards! Wouldn't want the welds on my tank exposed to that. Best way is to syphon it out (even though its slow) via the fuel line and then as Wart said "remove the sending unit" and either pump (with an approved gas pump) or syphon the rest out with a larger hose. Just be glad that you don't have a gas oil mix like I had years ago. And what to do with 3 year old gas, - well I went through it also and as someone said "I got rid of it very slowly".
read the tank sticker on your fuel tank-it clearly states maximumpressure test of 4psi!! if you pressurize that tank to 3-4psi it will empty.this is also the easiest way to remove water from the fuel system-especially after a submersion the water is heavier than the fuel and it will layer out pressurize the vent and blow the water out into a 5 g bucket till you have fuel done !! pressurizing the fuel tank is the safest way other option is to have the tank emptied by an environmental service-this will usually result in damage to eithe the fuel fill hose or the level sender
The wife and I hooked an electric fuel pump from my sons chevy v8 toyota pick up. in line with the fuel hose an the pick in the boat tank. then at the rear of my boat were the hose would have hooked to the motor sat a 55 gal drum. On the ground not in the boat.I hit the switch an presto tank drained drum filled
[:x)]
Slim[br]Lafayette [br]1973 19-6 Aquasport[br]An a few Makos[br]
