I have a hard top on my 240 cuddy, it is real mushy on the underside seems like it has seperated from the core. the top side has a dip in the center where the water sits on it after it rains can i cut away the core and replace it. if so with what material. and how do i get the curve back in it i think i can handle the work. have put a few floors in old boats and done minor glass repairs. thanks
NEED HELP ON HARD TOP
Yes you can make the repairs by just fixing the problem areas but it may be easier to just make a new hard top. There are a couple ways to do it. I made a cheap mold out of formica and particle board using some wood framing cut to camber. There is 3/8 inch core cell sandwiched between the layers of glass. Here are a couple pics and two links showing the construction. This was a easy project.
http://www.casdvm.com/photos/Hardtop/index.htm
http://www.casdvm.com/photos/SeaCraft%20Project/TOWER/
Strick
Oakley, California
Strick, thats fine looking work. Did you just gelcoat the mold and then layered over the wax? Might be dumb question but I'm willing to try this. Thanks.
Megabyte- The lights are great looking however the base that they attach to as already starting to rust a little...so I would not reccommend getting them...I got them from the place that did the welding for the hard top. I may have to have a aluminum base made for them or get different ones altogether.
Micura- I used duratec sanding primer as my first coat on the waxed mold. My plan was to awlgrip everything in the end which is what I ended up doing.
Strick
Oakley, California
