1982 Mako 17
  • 1982 Mako 17
    Here is a 1982 17 angler I found on boattrader not far from my home. He is asking 3990. He says the motor runs well but the steering rod is frozen in the motor and the owner also says the helm and steering cables need replacing. There are no hatches on the compartments in the back, he says the teak ones rotted away. I really want a standard model and am not sure I want to buy one right now. However, the gelcoat looks really good, the transom looks solid, he is including a gps and fishfinder and a vhf. He also says the gas tank was replaced in 1996. I am going to look at it tomorrow afternoon and will have more feedback then. What do you guys think?
    http://adcache.boattraderonline.com/6/5/2/77251852.htm
    SeaReel,
    Thats a pretty good price for an angler. They are realy desirable boats. I have an angler and a standard that I havnt worked on in a long time. Both are great boats. They are pretty roomy for a 17.
      How many Mako 17's do you have Gary?
      Cliff
        I have 2. My angler is a 72 and my standard is a 74. The standard is gutted now and im doing a complete rebuils on it.
          You might want to talk with a repair shop about the steering. Steering work can end up being pretty expensive.
            I looked at the boat yesterday evening. I am going to back off of it for now. The floor was soft in the back around the console. The transom had a crack running between the upper motor mounts and there were spider cracks all along the port side in addition to the problems I mentioned above. This is not something I want to tackle right now although it would be a great project.
            Cliff
              SeaReel,
              Thats probably a good idea. I thought the price was pretty good but not after what you mentioned. thats about a 1000.00 boat at best. My standard was in that shape and the whole boat was mush after I opened it up. Keep looking there are lots of good boats out there.
                Seareel,
                I replaced the helm and steering cable in my 1974 17 Classic a few years ago. I bought a Teleflex kit that included the helm and cable for around $200. You can buy them from any of the marine catalogues stores (West Marine, Boatersworld, etc.). Installation is fairly easy with the toughest part being trying to pull the end of the steering cable through the undersized pipe that Mako gave us under the deck. This was the 3rd or 4th steering cable for the boat.
                  Gary,
                  While we're on the subject of steering, What would be involved with hooking up hydraulic steering to a 17. I have to keep a solid grip on the wheel when running or getting out of the hole. I've been told a hydraulic system would be expensive but would be smooth as glass compaired to the cable setup. Any thoughts?
                  SB
                    There are cable steering systems that advertise "no feedback" I wonder if that would work well for your boat. These are the "rat-tail" type cables.
                      I installed a Teleflex 4.2 NFB steering system on my Grady when I repowered. Silky smooth operation and very low cost. I got the helm and cable from www.boatfix.com for around $140 I believe. That system would be a perfect match for a 17'er.
                      Brian[br]St. Leonard, MD
                        Thanks guys,
                        I really hoped I didn't have to install a hydraulic system. Too freakin' much $$$
                        SB
                          Hi Salty,
                          If you are having trouble with feed back in your steering that is due to your adjustment on that little trim thing on your lower unit. Hydralic steering is expensive but once you have it youll never go back. The teleflex system is a good system with little or no maint. I run a lot of HP on a small boat so if I used a teleflex unit I would have to use the high performace kit. In the long run the cost would balance. Use the cable nad you will be fine.
