Transom
  • Transom
    I purchased a 76 23' Mako last yr. The guys that owned it were kinda old and kept it inshore. We kingfish in some horrible weather sometimes, and have to travel close to 45 miles offshore to catch a good bottom fish or two. The boat has held up really well. But I noticed small chips at the corners of the of the transom where it turns up out of the spill well. Over the last dozen trips it has gotten alot worse. Probably about 10 inches of the jell coat have cracked and chipped out. We have checked the transom for softening and movement. But even with me putting most of my weight on the foot of the motor no movement is noticed. But obviously there is some movement. I wonder if I could go on the inside of the transom and beef it up with a stainless piece of angle. And then repair the cosmetics. Any Idea's ??????
    That might be the start of transom flex(failure) It would be good to get a profesional opinion, maybe get a moisture test done. I also put my 2 cents worth on your other post in project section. dave.
